Tranfer geometry from ICEM to CFX mesh
Old   November 12, 2006, 14:32
Default Tranfer geometry from ICEM to CFX mesh
Adam
Hi All,
I have an external surface file for my geometry in IGES format. I can read it at ICEM. In design modeler I cannot read it correct as it is surfaces only. I worked on it in ICEM and I have the correct geometry. How can I transfer it to Design Modeler or CFX Mesh? I'd like to make an inflation layer to be used for SST turbulence model.. How can I do this in ICEM...
Adam
Old   November 12, 2006, 15:55
Default Re: Tranfer geometry from ICEM to CFX mesh
Robin
You could try exporting it as a Parasolids, then reading this into DM or CFX-Mesh.
Old   November 12, 2006, 20:43
Johnny
Why not just mesh it in ICEM? Generate a prism layer off of your wall surfaces.
Old   November 12, 2006, 22:22
Adam
Thanks Johnny for reply. I understand that inflation layer is better than prism. Is that correct CFX experts?
Adam
Old   November 12, 2006, 22:33
Adam
I forget to mention that I also want to modify the geometry which is much easier to do by design modeler than using ICEM.
Adam
Old   November 13, 2006, 05:40
Johnny
An inflation layer and a prism layer are the same thing. I'd argue that since you have more controls in ICEM, that you would end up with a better quality mesh. But you could probably use either tool.
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 08:38
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 17:31
icem cfd geometry tin file not opening cfx 10 c mayur CFX 2 July 10, 2007 03:57
export mesh made in ICEM to cfx Morten Andersen Main CFD Forum 2 October 26, 2006 23:52
CFX mesh import from ICEM (Windows) Andrew CFX 7 July 6, 2006 12:39
