When I set the loss velocity type to superficial velocity, I have the same pressure drop and velocity as Darcy's equation. However, when I switch to true velocity, the velocity remains the same but the pressure goes more than 40 times higher. Does anyone knows why? Thank you for the reply
Dear ed,
The parameter Loss Velocity is to indicate the meaning of your loss coefficient.. That is, Loss = C * V_something then V_something can be either superficial (Darcy velocity), or true velocity = Darcy velocity / Volume Porosity.. They will give different pressure drops scaled by the volume porosity, or the square of the volume porosity.. All depends where you got your data from, or how it was correlated/measured. Opaque |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 15:37 |
Problems with Turbulence Modeling | ezsoal | OpenFOAM Running, Solving & CFD | 4 | November 26, 2009 15:12 |
LiftDrag tool | nuovodna | OpenFOAM Running, Solving & CFD | 45 | September 2, 2009 17:56 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
