December 30, 2020, 15:03 |
CFX-Net Head Gain Calculation
I am currently designing a pump that is from CFTurbo. To analyze it I am using CFX but when I get results in the expression tab I cannot see the net head gain. So I decided to create my own expression but I failed. This my expression (massFlowAve(Total Pressure)@volute outlet-massFlowAve(Total Pressure)@R1 Inlet)/(1050*9.81) So how can I achieve to define it? Or is there any solution it to solve automatically? Thank you. |
December 30, 2020, 17:59 |
Gert-Jan
Rep Power: 28 |
Why do you think it failed? Did you get an error or warning?
December 30, 2020, 18:15 |
for example increasing the mass flow rate should result in decreasing the net head gained.
In the parametric study I chose 5 design points in 3 of 5 trend is like that but after 6L/min it suddenly increases and continue like that |
December 31, 2020, 05:34 |
Gert-Jan
Rep Power: 28 |
It is difficult to say what went wrong. It could be anything. It depends a lot on how you have setup your case.
Are you convinced it has converged? Do you monitor this equation during the solving process? |
cfturbo, cfx, head, pump |
Gradient of a variable calculation in CFX PRE | Luigi | CFX | 2 | September 15, 2017 05:04 |
Net value Calculation for Standard Deviation | sagaramritkar | FLUENT | 0 | March 15, 2017 03:16 |
Reaction Force calculation in solid part in 2-way FSI simulation with CFX | esbolico | ANSYS | 0 | September 17, 2013 09:54 |
Calculation of ratational flow in CFX | Yves | CFX | 1 | January 27, 2004 17:48 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
