Timescale Information in the Output File
Old   November 4, 2006, 10:03
Default Timescale Information in the Output File
charles
Hi, i want to adjust that Timescale Information which, is been writing after every 5 iterations in the Output File, must been writen after 10 or 20 iterations. how to do it?
regards.
charles.
Old   November 6, 2006, 11:59
Default Re: Timescale Information in the Output File
Robin
Hi Charles,
You can either set a physical timescale, in which case the timescale is not updated at all, or add the Timescale Update Frequency parameter to the solver control (by editing your CCL in the command editor in Pre).
FLOW:
SOLVER CONTROL:
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 100
Timescale Control = Auto Timescale
Timescale Update Frequency = 10
END
END
END
Regards,
Robin
Old   November 6, 2006, 15:25
charles
Hi Robin, i thank you for your help. i want to consult about that Inc. viscous work term in total energy for heat transfer modeling with sst turb. modeling. to not choose that inc. viscous work term affects sst results? Can you explain shortly that sst and inc. viscous work term have how an interaction?
Again, thank you.
best regards.
charles.
Old   November 8, 2006, 10:32
Robin
Hi Charles,
The viscous work term will not effect convergence directly. This adds an additional source to the energy equation to account for work done by a moving wall on a fluid. If you walls are all stationary in the relative frame, it has no effect.
Regards, Robin
Old   November 8, 2006, 10:53
charles
Hi Robin,
The blade is my only wall in the rorating domain thus wall is moving as rotating wall.Then, inc. viscous work term will effect my result and i discovered that y+ is in the logaritmic bounary layer nearly turbulant layer. In that under the circumstances inc. viscous work term can work efficiently?
thanks for your reply.
best regards.
charles.
Old   November 8, 2006, 12:23
Robin
Hi Charles,
You said your blade is moving. Did you use a rotating frame of reference, or just specify a rotation of the blade?
Regards, Robin
Old   November 8, 2006, 16:03
charles
Hi Robin, I used a rotating frame of reference and my blade is wall with no-slip boundary condition. sst was used as turb. model and total energy as heat trans. model. I realized that my y+ is 10 which in the logaritmic boundary layer near the turbulent boundary layer. I think that is viscous boundary layer will not been resolved entirely. moreover, inc. viscous work term option will not help in the accurate heat transfer and sst calculatins. if you have different comment, please share it with me.
Regards...
charles.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
