December 25, 2020, 16:21 |
Two way FSI coupled system problems
Saeed Pashazanousi
Rep Power: 6 |
I'm using an student version of Ansys 2020 R2
I tried to simulate a plate oscillation affected by water free surface waves. First I simulate the oscillation plate tutorial...I get the result... Second I try to simulate my own case... My case is below Image: FSI2.png Fluid domain Mesh as Image below: FSI2-Fluid.jpg Solid domain Mesh as Image below: FSI2-Solid.jpg I used a coupled system to use two solver as image below: FSI-2way.jpg But I got this error after some coupled iterations as image below: FSI.jpg I search the error on the net but I didn't get the answer... I read some where student version not able to do a two way FSI coupled system...I contact with Ansys support but I don't get their answer yet... May be I asked a silly question as their sight... But I think problem is not the license... CFX output as follow: ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION =39000 CPU SECONDS = 1.835E+04 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom-Bulk | 0.95 | 9.2E-03 | 6.9E-01 | 7.1E-04 OK| | V-Mom-Bulk | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK| | W-Mom-Bulk | 1.16 | 7.1E-02 | 4.7E+00 | 7.0E-04 OK| | P-Vol | 0.97 | 1.3E-04 | 3.7E-03 | 9.9 2.9E-03 OK| +----------------------+------+---------+---------+------------------+ | Mass-Water | 1.00 | 2.2E-03 | 6.3E-02 | 10.6 3.4E-08 OK| +----------------------+------+---------+---------+------------------+ ================================================== ==================== Convergence Warnings Summary ================================================== ==================== +-------------------------+------------------------------------------+ | Equation Class | Solve Location | Number of | | | | Convergence | | | | Failures | +-------------------------+------------------------------------------+ | Momentum and Mass | DEFAULT | 1 | | Volume Fractions | DEFAULT | 1 | +-------------------------+---------------------------+--------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | A System Coupling error occurred while the request "AssignToken" | | was being served. | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine CP_ServeUntil | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory | | E:/Thesis/Elastic-Wall/Elastic | | Wall_pending/dp0_CFX_Solution_1/Fluid Flow CFX_002: | | | | 0_full.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | The ANSYS CFX Solver has written a crash recovery file. This file | | has been saved as E:/Thesis/Elastic-Wall/Elastic | | Wall_pending/dp0_CFX_Solution_1/Fluid Flow CFX_002.res.err and may | | be an aid to diagnosing the problem or restarting the run. More | | details should be available in the solver output section of the | | output file. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | E:/Thesis/Elastic-Wall/Elastic | | Wall_pending/dp0_CFX_Solution_1/Fluid Flow CFX_002: | | | | trace | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | For CFX runs launched from Workbench, the final locations of | | directories and files generated may differ from those shown. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished.
Best regards Saeed Pashazanousi Urmia University Email: st_s.pashazanousi@urmia.ac.ir |
ansys cfx, cfx, fsi 2-way coupling, worbench |
FSI system coupling problem | asoltoon | ANSYS | 1 | October 25, 2018 09:38 |
Time dependent piezoelectric actuation voltage with system coupling for 2 way fsi | Francis Hauris | ANSYS | 0 | April 1, 2018 22:23 |
2 Way FSI using System Coupling | salijav | ANSYS | 0 | December 21, 2015 02:36 |
help with basic coupled system | benk | OpenFOAM | 0 | February 17, 2010 16:44 |
interfced coupled system | jabe | CFX | 4 | April 22, 2002 19:28 |
