Simulating a gear pump for a finite volume
Old   December 25, 2020, 07:29
Default Simulating a gear pump for a finite volume
Vivek MJ
vivjk94 is on a distinguished road
Hello, i would like to do an analysis for a gear pump My main goal is to study the trapped volume in the gear teeth when the gears are meshing. Is it possible to do this in ansys cfx? how do i setup this control volume in ansys Cfx?
Please help me, i am new to Ansys cfx.
Thank you in advance
vivjk94 is offline   Reply With Quote
Old   December 26, 2020, 06:19
Is the trapped volume a purely geometric thing? If so, can't you do it with a solid modelling package and no CFD is required?
If I have misunderstood you, please explain what you mean by trapped volume.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 26, 2020, 06:28
Vivek MJ
By trapped volume I mean when the space between two gear teeths traps a volume from inlet, carries it against the pump casing and delivers it to the outlet.
I need to be able to determine how much volume is being trapped and delivered to the outlet for every rotation.
If I were to do it as solid modelling, how would I go about it?
Thanks for your inputs.
ansys cfx, control volume, gear pump
Matlab code for Finite Volume Method in 2D coagmento Main CFD Forum 5 October 7, 2022 14:47
The fundamental difference between Finite Difference and Finite Volume Methods vikramaditya91 Main CFD Forum 3 January 14, 2016 05:13
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
influence of convex or concave control volume in finite volume discretization openfoammaofnepo Main CFD Forum 1 March 24, 2014 03:13
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
