urgent help...pressurize inlet for multiphase flow
Old   November 2, 2006, 06:18
Default urgent help...pressurize inlet for multiphase flow
bernard
i wish to simulate a pipe with two inlet and single outlet. Inlet 1 will be pressurize gas 2 bar, inlet 2 will be pressurize gas 2 bar carried the particle wif 0.1g/s.
How to define the inlet condition for inlet 2? using satic pressure? mass flow rate? what about particle velocity?
i input static pressure 2 bar and velocity 0.5m/s get overflow why???
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
Mass flow inlet compressible flow richard FLUENT 2 June 1, 2008 12:44
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 07:45
Reversed flow in pressure inlet eric FLUENT 3 January 26, 2004 21:04
Mass flow inlet B.C. at exit... Jack Keays FLUENT 2 October 6, 2000 09:39
