INSUFFICIENT MEMORY ALLOCATED Error for FSI
Old   November 1, 2006, 20:37
Default INSUFFICIENT MEMORY ALLOCATED Error for FSI
Cuong
I run an FSI between CFX and ANSYS and recieved the following error:
*** INSUFFICIENT MEMORY ALLOCATED *** Action required : Increase the real stack memory size.
For a small number of nodes, the simulation is running well but when I refined the mesh I received the above error.
Is there any one know how to overcome the error?
I use ANSYS and CFX 10 running on a P4 3.0GHz, 1.5GB RAM
Thank you for shareing.
Cuong
Old   November 2, 2006, 05:21
Default Re: INSUFFICIENT MEMORY ALLOCATED Error for FSI
Patrick
Do as you are told: increase the real stack memory size... Or buy some more RAM .
How many nodes does your Mesh have?
Old   November 6, 2006, 20:48
Cuong
Thanks Patrick,
My computer has 2GB RAM already and I can not increase since windows 32 bit can only manage up to 2GB RAM.
The simulation that I have trouble with has just only 20K nodes ( just a small one). I can run transient with 400K on my PC but when I run FSI the code gave the warning like I presented. So I think there is some think else when settup the MFX simulation to overcome the "insurficient memory" error.
Cuong
*** INSUFFICIENT MEMORY ALLOCATED *** ?????? Pedro lima CFX 5 September 26, 2007 09:28
INSUFFICIENT MEMORY ALLOCATED Virag Mishra CFX 2 May 14, 2007 11:02
Insufficient Memory Allocated-error Juan Catelén CFX 2 April 4, 2007 04:57
INSUFFICIENT MEMORY ALLOCATED Jan CFX 2 July 16, 2003 01:55
INSUFFICIENT MEMORY ALLOCATED xfshi CFX 1 June 19, 2003 19:54
