general question about wall distance in ICEM + CFX
Old   October 31, 2006, 11:42
Default general question about wall distance in ICEM + CFX
Andy
I am wondering about the wall distance that is achieved by using the prism-mesher in ICEM.
The manual is telling that when boundary layer seperation from a smooth surface is supposed to be simulated there has to be a wall distance of the first node of 'Y+'<2. Therefore an equation is given that gives an idea what initial height for the first prism layer (or the first variable node?) should be selected in order to achieve this Y+. (Eq.20 in 'Guidelines for Mesh Generation')
My question is: When using CFX the finite volume approach is used and hence the flow variables are finally calculated at the centres of the cells,right? If that is the case then when setting the initial HEIGHT of the first prism layer I am actually setting up DOUBLE the distance of the required height? Is this fact already incorporated into the Eq.20 that means does the ICEM-manual account for a finite volume approach that is taking the mesh nodes as the FV-vertices and not as the FV-center?
I hope that this has not been to confusing and some pro out there is able to answer those questions... ;-)
Thanks anyway, Andy
Old   October 31, 2006, 11:55
Default Re: general question about wall distance in ICEM +
opaque
Dear Andy,
ANSYS CFX is a FV vertex based method, not a cell centered method.. That is, variables are computed at the ICEM mesh vertices. Will that explain your confusion?
Regards,
Opaque
Old   October 31, 2006, 12:00
Robin
Hi Andy,
The equation is only meant as a rough approximation and will get you in the right ball park. In terms of the actual location, CFX builds control volumes around the nodes of your mesh, which actually places a half control volume around the node at the wall, so the integration points are in fact located 1/4 of the distance to your first node.
In any case, don't worry about where the integration occurs. In the end, your Yplus is going to vary a lot over the surface. It won't hurt to have cells too close. At most, it may increase your mesh size by 1 or 2 percent (assuming you control your topology appropriately). It is better to have too much mesh in this case than to find you have too little later.
Regards, Robin
Old   November 2, 2006, 03:39
Andy
Thanks guys, but your answers raise two more questions:
Did I get it right that "opaque" is saying that CFX is vertex based (i.e. CV-vertex = Mesh-node) whereas "Robin" is saying that CFX is cell-centered (i.e. CV-center = Mesh-node)? So what is correct then?
@Robin: Does that mean when I am selecting a physical distance of 0.1mm for the initial height of my first prism layer the actual CV-center[=location for calculating the flow variables] is located at 0.1mm/4=0.025mm ?
Thanks and regards Andy
Old   November 2, 2006, 08:59
Robin
Hi Andy,
Opaqua and I are saying the same thing. When I said it builds control volumes around the nodes, I was referring to the corners of the elements.
Regards, Robin
Old   November 2, 2006, 09:20
Andy
Ah, right, my fault. Thanks for the help Robin, I really appreciate it. You are doing a great job!
Old   February 28, 2013, 02:44
Ajay Krishna
tmajaykrishna is on a distinguished road
I want to know how to calculate wall y plus (as in fluent) in CFX. which of the two variables ( y plus and wall distance) to be used to calculate
pls help
with regards,
Ajay Krishna
tmajaykrishna is offline   Reply With Quote
Automatic wall treatment in CFX Chander CFX 13 May 6, 2017 01:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
ICEM -CFX a basic question Al Mazdeh CFX 2 April 5, 2008 12:51
Question about bcdefw.f for wall temperature bc. Jimmy Siemens 10 March 18, 2008 16:28
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 05:29
