Can CFX handle local hex refinement?
Old   October 31, 2006, 05:22
Default Can CFX handle local hex refinement?
JollyP
i.e. is it possible to locally refine an unstructured hex mesh by local hex splitting? Fluent can handle this, can CFX without using manually defined interfaces etc?
Old   October 31, 2006, 08:52
Default Re: Can CFX handle local hex refinement?
myron
In CFX you will need to use generalized grid interfaces (GGIs) to handle such local refinements.
Old   October 31, 2006, 10:00
Robin
..or remove the hanging nodes by conforming the mesh.
[ICEM] Hex refinement negative quality afterwards Anorky ANSYS Meshing & Geometry 8 March 22, 2010 04:25
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
CFX local support in singapore Tej CFX 1 September 23, 2002 10:38
Local grid refinement with CFX-Build 4.2? Budi D CFX 0 May 31, 2001 09:34
