Can the Immersed solid function include other multiphase or heat transfer conditions? |
Younggi Park
Rep Power: 0 ![]() |
Hi guys
![]() I would like to ask the function of Immersed solid in CFX with heat transfer condition. When I used in Fluent 12.0, which is out of dats, it cannot support heat transfer function with Immersed solid method. I know there are many new versions, and I have 17.2 version, but it is hard to check the manual, so I leave a question. Is it possible to run it together in the new version? |
Rep Power: 144 ![]() ![]() ![]() ![]() |
The documentation is not that hard. You really should not be scared of it.
Your questions are answered in Solver Modelling guide, 1.2.10.2. This is in V20R2, it may be slightly different in your older version. I will leave sorting that out as an exercise in use of the documentation for the reader ![]()
heat transfer, immersed solid |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Immersed Solid Momentum Sources inside function | Martinw | CFX | 1 | October 10, 2013 17:14 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
