How to create a variable which computes vorticity |
October 28, 2006, 15:38 |
Hi, I have finished an analysis. it took long time. nearly 4000 iterations. so I selected 'standart variable list' in the Output Control section in CFX-Pre. now i am not seeing the ' vorticity variable' in CFX-Post. i needed create a variable that will calculate vorticities. so i defined a variable and used it. but it did not give reasonable results. Can any good human help me about that problem?
regards cmete |
October 30, 2006, 12:54 |
Re: How to create a variable which computes vortic
Add the following CCL to your def file:
LIBRARY: VARIABLE: vorticity Output to Postprocessor = Yes END END You'll then need to run your case for one more iteration to get a new results file that includes this variable. Hope this helps, Mike |
October 30, 2006, 15:07 |
You could also go back to Pre and add Vorticity to the res file through the Output Control panel. Use the new def file with your existing Res file to initialize it and run it for one iteration. Pretty much does the same as the above.
If you always want vorticity to be output, edit the $CFX_ROOT/etc/VARIABLES file in a text editor. Search for "VARIABLE: vorticity" and change the "Output to Postprocessor" parameter from No to Yes. Subsequent runs (on machines linking to this installation) will always include vorticity. Regards, Robin |
November 1, 2006, 02:38 |
Dear Sir,
Why you need "vorticity" and which it indicates. Thank you Eric |
November 1, 2006, 23:05 |
Dear Sir,
November 2, 2006, 16:24 |
thanks Mike for your advice. i think your way similar to Robin's. regards . cmete
November 2, 2006, 16:26 |
Hi, Robin i thank you very much. i tried your recommend. it works. best wishes. cmete
October 7, 2017, 10:54 |
problem in vorticity
Hamed
Rep Power: 9 |
Dear robin,
I have done all of that but my results were come all in blue!! whereas it was wind tunnel simulation I predict the wake vorticity must have been different can you advise me what i should do? |
[GAMBIT] Periodic BC | truffaldino | ANSYS Meshing & Geometry | 4 | June 5, 2011 07:39 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 12:32 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 02:40 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
About Vorticity Conservation. | Abhijit Tilak | Main CFD Forum | 7 | September 13, 2001 02:06 |
