Time to converge with free surface (PICTURE)
Old   October 27, 2006, 15:02
Default Time to converge with free surface (PICTURE)
Mark
I had posted a little ways back and got past my initial problems with my free surface flow. I believe it is now being solved appropriately, but it will not converge (as I read in the manual, its very likely free surface solutions will not converge due to little waves).
What I'm wondering is how long I should allow my simulation to solve for accurate results. I have stopped it after 400 iterations with a physical time scale of 0.01 [s] but the solution is not yet close to what I would expect from steady state.
Here is my setup:
It is essentially a 25" diameter bowl, spinning at 100 RPM with water being fed in to it through a pipe and that water climbing up the walls due to centrifugal force.
Old   October 27, 2006, 15:24
Default Re: Time to converge with free surface (PICTURE)
Mark
This is what my Momentum and Mass plot looks like after almost 500 iterations.
Old   October 29, 2006, 02:04
Chebeba
Dunno where your surface actually ends up, but it looks to me like you have a good boundary mesh for the wall interaction but the water surface will be somewhere in the middle where the mesh is very coarse?
You propably need a very fine mesh along the water surface too to get convergence.
Old   October 29, 2006, 11:05
Mark
Would you suggest I use a structured mesh throughout the domain?
Old   October 30, 2006, 08:37
Chebeba
Whatever suits you in order to get a mesh that has good resolution perpendicular to where you expect to find your free surface. But yes, this is usually easier with a structured mesh.
I would also suggest a run with Interface Compression = 2 to see if that changes anything.
Old   October 30, 2006, 12:07
Charles
This is easy to mesh with a structured mesh, so it would be a very good idea to do so. Once you have a good idea of where the free surface is, try to construct a mesh that is close to parallel to the free surface in that region, with very fine vertical spacing.
Old   October 30, 2006, 13:23
Mike
Hi Mark, a few additional suggestions that may help:
- It looks like you can reduce your problem size by taking a small slice instead of a 90 degree slice. I would make the mesh 1 element thick in the circumferential direction. You can create a 2D extruded mesh in CFX-Mesh to do this.
- Estimate how long it would take to reach steady-state if you actually had this set up. How much water do you expect to get in the bowl, how much do you start with and how much are you introducing? 400 iterations at 0.01[s] gives you 4[s]; if in reality it would take longer than this to reach a steady-state condition then you'll likely need more iterations, or an initial guess closer to the solution. Hope this helps, Mike
Old   October 30, 2006, 21:46
Mark
Mike, Charles, Chebeba,
Thank you all for your help. I was able to get the solution to converge after a great amount of iterations and the reason it was taking so long is because my initial guess was so far off (glad I did the simulation!).
Since I have to do a number of simulations like this, I will take your advice Mike and try it as 1 element thick. I will also make the mesh structured and more fine.
Again, thank you all.
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
free surface around a ship hull Stephy OpenFOAM Running, Solving & CFD 12 April 24, 2012 02:12
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 21:13
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
