Help needed with free surface simulation
Old   October 24, 2006, 09:21
Default Help needed with free surface simulation
Mark
I have a simulation with a open-top container completely full of air (i.e. domain's initial condition of air's volume fraction is 1). This container's walls are spinning, and I am injecting water into the domain through an inlet, such that the water builds up on the walls and exits the container continuously.
Everything seems to solve fine as a steady state problem, but when I look at my results there is hardly any water in the container (i.e. the volume fraction of water is way too low on the walls of the container, where it should be about 1).
Does anyone have any idea what I might be doing wrong?
Old   October 24, 2006, 18:51
Default Re: Help needed with free surface simulation
Johnny
What are your imbalances like? Are you conserving mass? What does your BL mesh look like? Do you have buoyancy turned on?
Old   October 26, 2006, 15:43
Mark
Johnny, Thanks for the response.
I have buoyancy turned on and much of the simulation is based on the tutorial "Free surface flow over a bump".
I have an inflation layer around the outer edge of my device, which is essentially a bowl. So I have inflation elements on the walls of the bowl where water will build up.
I'm not sure what you mean by conserving mass or imbalances. The mass should not be conserved because I have an opening so mass can flow in and out.
If I create an isosurface at "volume fraction of water = 0.5", the only surface I see is right around the inlet. However, if I turn this down to much lower values (<0.1), I begin to see the flow of the water up the edges of the bowl.
It almost seems like the water is vaporizing.
Old   October 27, 2006, 03:15
Jason
you can create a plane,and select the color as variables,then select the volume fraction --0.5,then you can see what you want,if you had the right setting and solving.
Good luck Jason
Old   October 27, 2006, 13:07
Mark
I'm now finding that my solution won't converge. What is a typical time frame for convergence of a free surface, steady-state, problem (should I be allowing it to run all day or should I expect accurate results within a few hours)?
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 12:44
Problem Concerning free surface wave simulation michaels STAR-CCM+ 3 February 25, 2011 08:28
How to define size of domain for free surface simulation? Sunya Main CFD Forum 2 June 9, 2009 00:33
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 12:57
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 16:56
