October 19, 2006, 04:41 |
Total Head Pump Prediction
I'm working with a pump stage. As suggested by cfx edited documents, I'm setting inlet condition as relative pressure, and outlet as mass flow rate. Can I expect the simulation to produce an accurate value of pressure averaged on the outlet area?
Furthermore, supposing I could get total head pump by experimental data, should i set it as outlet boundary condition and mass flow rate as inlet? Thanks |
October 26, 2006, 14:11 |
Re: Total Head Pump Prediction
Hi. In such a case I always use mass flow inlet/average static pressure outlet as the bc. If your mesh is fine enough to include the both leakage rooms and has the domain interface placed at the proper place, the error of the head will be smaller than 3%.
And I don't think specify only the outlet using experimental data will do you any good. |
October 27, 2006, 04:55 |
Any suggestion for the domain interface placing? Thanks.
Total pressure in CFX | famarcfd | CFX | 0 | June 17, 2011 10:33 |
Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
How do I find the pressure head for centrifugal Pump | dsuneail | CFX | 1 | March 2, 2010 16:53 |
pump head gain | ranjith | CFX | 0 | March 18, 2008 06:06 |
Discharge pump flow | Ali | Main CFD Forum | 0 | March 5, 2003 17:11 |
