Difference between Hex and Tetra in CFX
Old   October 23, 2006, 22:31
Default Re: please ignore last posting
  #21
TB
You need to validate your results. CFD has not yet reached the stage that it can be used solely without validation. Tet+prism is not really bad in all cases. It's problem dependent. I did see some authors getting a good result using tet+prism mesh in their flow problems.
Old   October 24, 2006, 09:06
Default Re: Difference between Hex and Tetra in CFX
  #22
Robin
Hi TB,
I don't disagree with you and never said that unstructured meshes should be used whenever possible. Actually, if anything I would state the opposite, that whenever <bi>possible</bi> you should use a hex mesh.
The point is not to bend over backwards to get a mesh of a particular type (or to avoid another). The main objective should be to get a mesh with appropriate resolution and validate your application accordingly.
Regards, Robin
Combining Hex and Tetra Mesh ZenCef ANSYS 7 November 10, 2011 06:04
[ANSYS Meshing] Meshing in CFX zephyrus17 ANSYS Meshing & Geometry 0 October 5, 2011 22:14
Urban scenario - tetra vs hex problem pablocg OpenFOAM Running, Solving & CFD 6 April 9, 2009 04:14
Octree Vs Advancing Front tetra meshing techniques Sam CFX 4 February 18, 2008 09:54
Difference in Hex and Tet mesh san FLUENT 2 May 11, 2006 07:13
