Pedro Dieguez
Rep Power: 6 ![]() |
ANSYS-CFX Free suface model.
The simulation es very simple: Box with water and air; no movement. CFX-Pre: Homogeneous model, free surface model standard, isothermal, laminar, fluid bouyancy model: density difference, surface tension mode: none, interface transfer: free surface. Initial conditions are: zero velocity, volume fraction of water and air and pressure. Steady state. InitialZ (height of water): 0 [m] initial water volume fraction: if((z<InitialZ), 1, 0) initial air volume fraction: 1 - OceanoVFAgua initial pressure: if((z<InitialZ), ((997 [kg m^-3] - 1.185 [kg m^-3])*g*(InitialZ-z)), 0 [Pa]) After run, the results are: hidrostatic pressure OK low or very velocities (1e-3 m/s), but they must be zero and Normalised Imbalance Summary | +--------------------------------------------------------------------+ | Equation | Maximum Flow | Imbalance (%) | +--------------------------------------------------------------------+ | U-Mom-Bulk | 1.2143E+06 | 0.0000 | | V-Mom-Bulk | 1.2143E+06 | 0.0000 | | W-Mom-Bulk | 1.2143E+06 | -0.0005 | | P-Vol | 2.9663E-04 | -100.0000 | +----------------------+-----------------------+---------------------+ | Mass-Water | 1.6829E-15 | -100.0000 | +----------------------+-----------------------+---------------------+ Does anyone know if this is correct? Why these imbalances? Thanks in advance. Best regards. |
Gert-Jan
Rep Power: 27 ![]() |
Mass imbalance is based on amount of inflow. If there is no inflow, then there is no reference and mass imbalance is 100% in your case.
Pedro Dieguez
Thank you very much for your help, Gert-Jan.
cfx-pre, free suface, p-vol imbalance |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
No macrosegregation when setting symmetry condition at free surface | durg | FLUENT | 0 | July 29, 2019 01:25 |
No macrosegregation when setting symmetry condition at free surface | durg | Fluent UDF and Scheme Programming | 1 | July 29, 2019 00:25 |
how to capture free surface cells? | MichaelVS | FLUENT | 1 | June 10, 2015 02:18 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
