Pump stage: Simulation using momeuntum source???
Old   October 8, 2006, 11:17
Default Pump stage: Simulation using momeuntum source???
Peter
hi,
I would like to simulate one stage of a PUMP. I know radial and circumferential velocity components at the outlet of rotor. (or in other words: in Inlet of diffuser blades). As I understood from CFX help, I should use general momentum source to achieve specific velocities known at outlet of rotor.
But im confused how to set up momentum source coefficient and velocity components??
Perhaps: Momentumsource_radial= momentum source coefficient* (VelocityLocal - VelocityGiven)
Is that true?????? then how to find Velocity Local???
Regards,
Convergence problem with axial pump simulation! cnchilavert CFX 2 October 5, 2011 05:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
modeling a pump as momentum source Priscila CFX 4 June 6, 2007 11:08
