MFX: weired force transfer from cfx to ansys
Old   October 6, 2006, 01:58
Default MFX: weired force transfer from cfx to ansys
zyf
I'm using cfx 10.0 and ansys multiphysics 10.0 to simulate a fluid-structure interaction problem. The model is very simple, just a flat panel with fluid flows above it. cfx run in transient mode, ansys run in steady mode.
cfx solver run first and then ansys. after first cfx run, the pressure on panel should be 1 atm (101325Pa), and force 101325N (the panel is 1x1 in gemotry), it does right. then the pressure load tranftered to ansys, but after reviewing ansys output file, I find the force is 0.10133E+7, which is 10 times to cfx load. It's WRONG, because the load relax factor has been set to 1, these two force should be equal.
has anyone found this problem?
Old   October 6, 2006, 13:34
Default Re: MFX: weired force transfer from cfx to ansys
Fingers
Do you have a username / password to the CFX community site?
Old   October 6, 2006, 13:37
Fingers
Looking under the CFX technotes at example they given.
Old   October 7, 2006, 04:08
zyf
I can't access to CFX community site now. Would you send me a copy of that example?
ANSYS Multi-physics and CFX coupling error anujit CFX 3 June 21, 2009 19:39
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
Temperature transferring from CFX to ANSYS? Se-Hee CFX 0 November 28, 2006 06:56
ANSYS to acquire CFX Fred FLUENT 0 February 18, 2003 22:04
ANSYS to acquire CFX Fred Siemens 0 February 18, 2003 22:03
