CFX and LES
Old   October 4, 2006, 09:40
Default CFX and LES
Bruno
I'd like to know anything about the use of CFX to solve turbulence simulations by LES. I'm a researcher simulation and dispersion of pollutants around buildings using numerical solutions.
Thanks
Old   October 4, 2006, 09:54
Default Re: CFX and LES
Joe
Google + RTFM
Old   October 4, 2006, 14:08
ben akih
hi bruno, i wonder whether this is possible with cfx 10. there is some information about LES in the user manual but LES as a turbulence model option is not listed in the CFX Pre. I have not worked with LES but as i hear it can be quite challenging to prescribe the boundary and initial condition. do some literature research on that. most people working with les rather use in house codes. good luck ben
Old   October 4, 2006, 14:12
johnny
LES is available in Pre - assuming you have set up a transient simulation. Obviously it is not available for steady state.
Old   October 4, 2006, 16:40
Jens
Yes this it dully possible. I have used it. Also check HSL homepage for report on LES and CFX.
Regards
Jens
Old   October 5, 2006, 13:29
Ademola
Well, LES is one of the three major ways to solve dispersed flow problems. The other two are RANS and DNS. The beauty of LES is that the dynamics of large particles are calculated directly while the small droplets are accounted for in more precise manner.
It is however computationally expensive to execute.
Contact me if you don't mind, I did a research relating to dispersed flow too.
What happens to CFX when I run LES? ursh CFX 1 June 1, 2017 05:10
CFX 11 Scheme for LES in Multiphase Man CFX 12 May 25, 2009 21:26
have anybody use the LES in CFX? Wei CFX 3 April 17, 2008 20:34
LES of Non-Premixed Combustion in CFX?? Manu CFX 5 February 25, 2008 17:34
CFX 5.5.1 stirred tank and LES problem Nishant CFX 2 September 13, 2002 08:11
