mesh for a high aspect ratio geometry
Old   October 2, 2006, 06:41
Default mesh for a high aspect ratio geometry
matthias
Hello everyone, I try to create a mesh with ICEM for an angel of a tube. Because of the very small diameter this geometry has a great aspect ratio (about 2000). I already created a mesh (extrude by rotation) for only a small part (10mm length) and now I tried to create it in the same way for 1000mm length. But now it doesn't work. The final number of elements can't be too much, because it's about 900 000 elements. Is there anything I have to consider for this high aspect ratio? Thanks Matthias
Old   October 2, 2006, 22:56
Default Re: mesh for a high aspect ratio geometry
Roberto Lourenço
I had the same problem. My channel's diameter is 280 microns and the lenght is 79 mm. How do we proceed?
Old   October 3, 2006, 09:32
myron
Try reducing the triangle-tolerance value from the Global Meshing parameters panel. Maybe to 1e-5 or 1e-6. This will give better geometry resolution and may help. You could also try scaling the geometry to create the mesh - then rescale back down to true size.
Old   October 20, 2006, 03:55
matthias
I don't know if that was really my problem, but I had used double node cheking when I imported the mesh into CFX Pre. Without it it works. Matthias
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
re: Viewing High aspect ratio elements in CFX post MMG CFX 1 December 13, 2006 07:26
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
