Why P-Mass imbalance =+ - 1solution seems physical
Old   September 29, 2006, 08:35
Default Why P-Mass imbalance =+ - 1solution seems physical
Dai
Dear, all may be anybody could know the reason..
I have set that the density of the fluid is temperature dependant. My thermal/cfd calculation solutions seems quite physical,as well as Max residuals seems fine. In the same time P-Mass imbalance (imbalance of equation) is jumping streight from -1 to 1 and back - each iteration.
If I set a constant density - P-Mass imbalance is 0.
Is it OK with the values 1 and -1 (it is recomended 0.01 default value for conservation target)?
Old   September 29, 2006, 08:54
Default Re: Why P-Mass imbalance =+ - 1solution seems phys
Phil
Do you have a closed system? The individual contributions to the imbalance may then all be close to zero and the +1/-1 switching due to the fact that there is nothing meaningful available to normalize an imbalance which is actually roundoff.
Old   September 29, 2006, 09:21
Dai
Yes, my system is closed. Did I understand correctly - everything is fine because the value, which is normalised is not important because very small. If so - thank you
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
OutletBoundary Condition Causes Mass Imbalance Andy Main CFD Forum 0 March 11, 2004 15:05
Residual Problem -Mass Imbalance Jie FLUENT 0 February 19, 2002 11:49
