Effect of wall temp. on convergence
Old   September 26, 2006, 08:18
Default Effect of wall temp. on convergence
ben akih
Hi folks, has any body in here experienced a situation whereby the wall temperature affects seriously the convergence of a simulation? I am simulating flow at high mach numbers. the free stream temperature is 262 k. i obtained converged solutions with a wall temp of 500k but cannot obtain a solution with 300k. The solution terminates with a FINMES error. will be grateful for some tips. regards, ben
Old   September 26, 2006, 18:18
Default Re: Effect of wall temp. on convergence
If you have natural convection effects activated the wall temperature defines the Rayliegh number of the simulation and therefore strength of the flow. Obviously in this case the wall temperature will effect convergence.
In your case you say that reducing the wall temperature lead to convergence problems. This sounds a little strange. What are you modelling?
regards, Glenn Horrocks
Old   September 27, 2006, 04:09
Ben akih
hi Glenn, thansk for your reaction to my post. I am dealing with hypersonic flow over a zero degree of attack plate. I seem to have found the reason for it. because of the high velocities involved, in my case mach 7.5 that is about 2376 m/s, the static temperature rises sharply in the boundary layer. for a free stream static temperature of 260k and a wall temperature of 300k, the static temperature reaches values of over a 1000k within 0.2mm distance from the wall. this leads to very high gradients. the effect is less with higher temperatures. since the cfx solver is implicit, besides a fine BL resolution, a good guess of the initial field is necessary. i am trying to get a profile around the midplate to use as initial value. seems to work well for laminar up to a convergence target of 1e-5 max residual. waiting to see if the transitional simulation will converge. thanks anyway. Glenn, have you worked with the SST two equation transition model before? i need to exchange experience with someone who has used this before. regards, ben
Old   September 27, 2006, 18:25
I don't have much experience in modelling hypersonics so I don't think I can help you much. I have used the SST transition model, but again not in hypersonics.
So for some suggestions: Make sure the solver is doing the extra Pressure/mass solution each iteration, and carefully check the various convergence options - local timescale factor versus physical timestep.
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Velocity and Temp. jump on wall p_agoodboy FLUENT 0 March 27, 2011 22:53
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
