Jiri
Rep Power: 13 ![]() |
Hi there,
I simulated a hydrodynamic bearing operation being lubricated by oil. Since it is possible that air may be sucked into the bearing, I included the air onto a surface as boundary condition. The trouble is, that the computation runs only with Air at 25C which has constant density. Applying Air ideal gas leads to divergence due to overflow. Playing with timescale does not work as well as improving mesh quality. Are there any ideas for oil - ideal gas mixture? |
Rep Power: 144 ![]() ![]() ![]() ![]() |
It is normal that when you make the physics more complex that convergence is harder. You have replaced an incompressible fluid with a compressible one, so now you should expect pressure wave effects, compression, adiabatic heating and cooling and all those sort of complex physics.
Without specific details I cannot help, but this simulation sounds highly transient and will require a VERY small time step. Have a look at the CFL numbers for your flow now you are using a compressible fluid, that will guide you to the sort of time step size you need.
Jiri
Thank you for the reply. Is there any document how to set CFL for multiphase analyses? Must the Courant number be always below 1?
No, CFX is an implicit solver and is not restricted to a CFL or Courant number. I generally recommend you use adaptive time stepping, homing in on 3-5 coeff loops per iteration for transient simulations.
If you want to Courant Number (or CFL for compressible flows) then aim for about 1 to 10 - the actual requirement could be higher or lower than that, but that is a starting point.
Air Liquid Mixture simulation in a hydrocyclone | Navillera | Fluent Multiphase | 2 | September 7, 2019 23:50 |
multiphaseEulerFoam convergence problems | Stefanie.S.W. | OpenFOAM Running, Solving & CFD | 6 | August 28, 2019 04:15 |
How to derive an Equation of State for a mixture of Liquid-vapor and air | mg.mithun | Main CFD Forum | 0 | April 12, 2016 11:32 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
