Ansys CFX10: multiphase reaction heat problem
Old   September 18, 2006, 10:20
Default Ansys CFX10: multiphase reaction heat problem
CFDS
for one multiphase reaction:
CaCO3(solid particle)->CaO(solid particle)+CO2(gas)-1.66E6 J/kg,@870 Celsius degree.
In Ansys CFX 10.0, the reaction rate can be easy set, and the mass rate interphase is solved.
But for the the reaction heat of the chemical reaction, the I try set the "HEAT RELEASE" with two kind way,
The first way:
HEAT RELEASE:
Latent Heat = 1.66E6 [J kg^-1]
Option = Latent Heat
Reference Material = caco3
Reference Parent Material = limestone
Reference Temperature = 800 [C]
END
the second way:
HEAT RELEASE:
Option = Specific Enthalpy
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 1.66E6 [J kg^-1]
Reference Temperature = 0 [C]
END
But according to the solution output, the reaction heat is more than the 1.66E6 J/kg.CaCO3 up to 2 times.
I don't understand clearly the reason about it.
Maybe the released CO2 get into the gas phase with formation heat?
Would someone give me hand on this?
thanks in advance!
Old   September 21, 2006, 00:09
Default Re: Ansys CFX10: multiphase reaction heat problem
Leo s
In order to add the formation enthanpy of CO2 at 298Cdeg and 1 atm, the "HEAT RELEASE" is modified to
H_co2_f*44/100-1.66E6 [J/kg],
but the result is not good.
what's wrong?
Heat transfer problem seojaho CFX 6 May 6, 2010 01:32
Heat transfer problem in ansys please help me please...!!!!!!! rm2052 CFX 1 March 14, 2010 18:51
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Multiphase multicomponent masstransfer and heat transfer problem rajeevrkris OpenFOAM Running, Solving & CFD 0 February 6, 2008 04:21
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
