September 27, 2020, 14:46 |
CFX Solver exited with warning
PENANG
Rep Power: 9 |
Hi I am using CFX solver for an oscillating airfoil. I am hereby attaching the cfx.out file content in txt file.
It says negative volume and skewness warning, but I checked my mesh, there is no negative volume or badly skewed elements. I am attaching pictures. Kindly help me. Thanks in advance. |
September 27, 2020, 16:52 |
Rep Power: 14 |
is it 2Dor 3D? Maybe at the tip, if its a sharp edge, then it made a twisting surface? Maybe make a small fillet there?
September 27, 2020, 17:08 |
PENANG
Rep Power: 9 |
Hi Steffen, thank you for your reply. It is a blunt TE. The mesh is good at the TE. Any other reason. I am not able to figure out. I even improved the mesh further. But same issue.
September 28, 2020, 04:10 |
Rep Power: 14 |
maybe there is a surface or its a multi-body part?
September 28, 2020, 08:06 |
Rep Power: 33 |
It seems you are repositioning the coordinates, not displacing them.
For this type of problem (where there is periodic boundary motion), I usually follow: Use mesh deformation with the automatic blended mesh stiffness option and Displacement Relative to Initial Mesh For the moving boundary, I use an expression for the displacement in Cartesian Coordinates. I rarely use the Location option. Perhaps there is an error in the motion of the boundary.
September 28, 2020, 14:08 |
PENANG
Rep Power: 9 |
Hi Opaque,
Thank you for your time and reply. I will follow up your suggestions. I see there are two types of displacements, specified and periodic..which one should I select. Will the expressions change for x, y and z coordinates as I have put in case of specified location? For now, I am using Initial X *cos(ai)-Initial Y * sin(ai), Initial X *sin(ai)+Initial Y * cos(ai) and Initial Z, where ai is mentioned expression. Can you please clear my concept. I am using this first time. Thank you. |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
