Regarding holes in Tetra mesh
Old   September 12, 2006, 10:22
Default Regarding holes in Tetra mesh
swamy
I am new to icem i am doing meshing of condenser, in which lover type of fin arrangment.when i do tetra mesh then i find some portion on fins in which there is no meshes or holes types. how to remove that holes , if i do manually then it gives surface orientation problem and volume also. kindly help me.
Thanks
Old   September 12, 2006, 11:00
Default Re: Regarding holes in Tetra mesh
Joe
Get your topology fixed. You have a leaky surface set.
Old   September 12, 2006, 16:11
Michael
there are also surface hole fixing capabilities in ICEM, but I rarely use them as I correct the geometry in UG
Old   September 13, 2006, 09:35
myron
You could also try specifying a smaller mesh size on the louvers/fins. Sometimes the mesher has a difficult time resolving both sides of features that are very close together.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 20:39
[ICEM] ansys icem tetra mesh to fluent_v6 conversion problems milleniumrider ANSYS Meshing & Geometry 5 May 20, 2010 16:55
