Problem setting boundary condition from file
Old   September 11, 2006, 17:31
Default Problem setting boundary condition from file
Antonis
Hi all!
I doing a simulation on a boundary layer, so I need exact boundary conditions, data taken from DNS. When using the BSL Reynolds stress model, I need to set as turbulence quantities the Reynolds stresses (uu,vv,ww and uv/it's 2-D) and the epsilon. I prepare the data file, according to the cfx manual and then load it into CFX. However, when I try and start the simulation, I receive an error saying that the specified by me reynolds stresses cannot be read because they contain an "unrecognised name". I'm using as variable names the "rs uu" etc. ,as explained in the manual. I cannot understand where the problem is.
Any help would be highly appreciated!!
Antonis
Old   September 11, 2006, 17:53
Default Re: Problem setting boundary condition from file
Joe
Run the simulation without user specified inlet conditions for a few iterations. Open the results file in post and export the quantities you are interested in for the inlet only. Have at look at the format of the file, including naming. Re-work this example file to contain your DNS data.
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 23:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
