Two-Phase Buoyant Flow Issue
Old   August 30, 2006, 12:42
Default Two-Phase Buoyant Flow Issue
Miguel Baritto
Hi all
I am using CFX 10.0 in order to simulate air bubble behavior rising in a vertical pipe filled with stagnant water. I have chosen the follow sets: simulation type: transient, free-surface model, buoyant flow, gravity vector: (0;0;-9.81), reference density: rho.air, Surface tension: 0.0718 N/m. I started from a spherical bubble which is located in pipe bottom. However, bubble does not rise. what is wrong?
Thanks for your help
Old   August 31, 2006, 11:04
Default Re: Two-Phase Buoyant Flow Issue
Joe
Post your command file
Old   August 31, 2006, 11:48
Miguel
Joe, thanks a lot for your reply. This is my ccl file, If you need any file please give me your e-mail and I send to you.
# State file created: 2006/08/28 11:44:23 # CFX-10.0 build 2005.10.26-23.10
FLOW: COORD FRAME:Coord 1
Axis 3 Point = 0 [m], 0 [m], 1 [m]
Coord Frame Type = Cartesian
Option = Axis Points
Origin Point = 0 [m], 0 [m], 0 [m]
Plane 13 Point = 1 [m], 0 [m], 0 [m]
Reference Coord Frame = Coord 0 END DOMAIN:conducto
Coord Frame = Coord 1
Domain Type = Fluid
Fluids List = Air Ideal Gas,Water
Location = Assembly
BOUNDARYared
Boundary Type = WALL
Location = F16.17,F18.17,F19.17,F20.17,F21.17,F22.17
FLUID:Air Ideal Gas
BOUNDARY CONDITIONS:
WALL INFLUENCE ON FLOW:
Option = Free Slip
END
END
END
FLUID:Water
Option = No Slip
WALL VELOCITY:
Option = Cartesian Components
Wall U = 0 [m s^-1]
Wall V = 0 [m s^-1]
Wall W = 0 [mm s^-1]
END
END
END
END
WALL CONTACT MODEL:
Option = Use Volume Fraction
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Density = 1.164 [kg m^-3]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = 0 [m s^-2]
Gravity Z Component = -9.81 [m s^-2]
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Cartesian Coordinates = 0 [m], 0 [m], 0.03 [m]
Option = Cartesian Coordinates
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID:Air Ideal Gas
FLUID MODELS:
FLUID BUOYANCY MODEL:
Option = Density Difference
END
MORPHOLOGY:
Minimum Volume Fraction = 10e-12
Option = Continuous Fluid
END
END
END
FLUID:Water
FLUID MODELS:
END
MORPHOLOGY:
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Fluid Temperature = 30 [C]
Homogeneous Model = False
Option = Isothermal
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
FLUID PAIR:Air Ideal Gas | Water
Surface Tension Coefficient = 0.0718 [N m^-1]
INTERPHASE TRANSFER MODEL:
Maximum Length Scale for Area Density = 0.1 [mm]
Option = Free Surface
END
MASS TRANSFER:
Option = None
END
MOMENTUM TRANSFER:
DRAG FORCE:
Drag Coefficient = 0.44
Option = Drag Coefficient
END
END
SURFACE TENSION MODEL:
Curvature Under Relaxation Factor = 0.25
Option = None
Volume Fraction Smoothing Type = Volume-Weighted
END
END
INITIALISATION:
Option = Automatic
FLUID:Air Ideal Gas
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic with Value
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [mm s^-1]
END
VOLUME FRACTION:
Volume Fraction = FVG
END
END
END
FLUID:Water
INITIAL CONDITIONS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
VOLUME FRACTION:
Volume Fraction = FVL
END
END
END
INITIAL CONDITIONS:
STATIC PRESSURE:
Relative Pressure = PI
END
END
END
MULTIPHASE MODELS:
FREE SURFACE MODEL:
Interface Compression Level = 1
Option = Standard
END
END END OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS:Transient Results 1
Include Mesh = No
Option = Selected Variables
Output Variables List = Absolute Pressure,Air Ideal Gas.Smoothed Volume Fraction,Air Ideal Gas.Velocity u,Air Ideal Gas.Velocity v,Air Ideal Gas.Velocity w,Air Ideal Gas.Volume Fraction,Total Pressure,Water.Smoothed Volume Fraction,Water.Velocity,Water.Volume Fraction
Time Interval = 0.1 [s]
END END SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 5 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.1 [s]
END END SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s] END SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 10
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END END END
LIBRARY: CEL:
EXPRESSIONS:
FVG = 1-FVL
FVL = step(esferoide)
PI = g*997[kg m^-3]*(0.03[m]-z)
esferoide = x^2/(0.4*1[mm^1])^2+y^2/(0.4*1[mm^1])^2+(z-4[mm^1])^2/(3*1[mm^1])^2-1
END END MATERIAL:Air Ideal Gas
Material Description = Air Ideal Gas (constant Cp)
Material Group = Air Data, Calorically Perfect Ideal Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Molar Mass = 28.96 [kg kmol^-1]
Option = Ideal Gas
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
SPECIFIC HEAT CAPACITY:
Option = Value
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-2 [W m^-1 K^-1]
END
END END MATERIAL:Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
PROPERTIES:
Thermal Expansivity = 0.003356 [K^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Option = Value
END
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
END
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
END END MATERIAL:Water Ideal Gas
Material Description = Water Vapour Ideal Gas (100 C and 1 atm)
Material Group = Calorically Perfect Ideal Gases, Water Data
PROPERTIES:
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 9.4E-06 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Molar Mass = 18.02 [kg kmol^-1]
Option = Ideal Gas
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Reference Pressure = 1.014 [bar]
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
Reference Temperature = 100 [C]
Specific Heat Capacity = 2080.1 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 193E-04 [W m^-1 K^-1]
END
Material Description = Water (liquid)
Material Group = Water Data, Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
Thermal Expansivity = 2.57E-04 [K^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997.0 [kg m^-3]
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
Option = Value
END
Option = Value
Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 0.6069 [W m^-1 K^-1]
END
END END MATERIAL:Aluminium
Material Group = CHT Solids, Particle Solids
Thermodynamic State = Solid
PROPERTIES:
EQUATION OF STATE:
Density = 2702 [kg m^-3]
Molar Mass = 26.98 [kg kmol^-1]
Option = Value
END
Option = Value
Reference Specific Enthalpy = 0 [J/kg]
Reference Specific Entropy = 0 [J/kg/K]
Specific Heat Capacity = 9.03E+02 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 237 [W m^-1 K^-1]
END
END END MATERIAL:Steel
PROPERTIES:
EQUATION OF STATE:
Density = 7854 [kg m^-3]
Molar Mass = 55.85 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 60.5 [W m^-1 K^-1]
END
END END MATERIAL:Copper
PROPERTIES:
EQUATION OF STATE:
Density = 8933 [kg m^-3]
Molar Mass = 63.55 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 3.85E+02 [J kg^-1 K^-1]
END
Option = Value
Thermal Conductivity = 401.0 [W m^-1 K^-1]
END
END END MATERIAL GROUP:Air Data
Group Description = Ideal gas and constant property air. Constant properties are for dry air at STP (0 C, 1 atm) and 25 C, 1 atm. END MATERIAL GROUP:Water Data
Group Description = Liquid and vapour water materials with constant properties. Can be combined with NASA SP-273 materials for combustion modelling. END MATERIAL GROUP:Gas Phase Combustion
Group Description = Materials which can be use for gas phase combustion. Properties are specified using the NASA SP-273 format. END MATERIAL GROUP:Constant Property Gases
Group Description = Gaseous substances with constant properties. Properties are calculated at STP (0C and 1 atm). Can be combined with NASA SP-273 materials for combustion modelling. END MATERIAL GROUP:Calorically Perfect Ideal Gases
Group Description = Ideal gases with constant specific heat capacity. Specific heat is evaluated at STP. END MATERIAL GROUP:Constant Property Liquids
Group Description = Liquid substances with constant properties. END MATERIAL GROUP:CHT Solids
Group Description = Pure solid substances that can be used for conjugate heat transfer. END MATERIAL GROUP:Particle Solids
Group Description = Pure solid substances that can be used for particle tracking END MATERIAL GROUP:Soot
Group Description = Solid substances that can be used when performing soot modelling END MATERIAL GROUP:User
Group Description = Materials that are defined by the user END MATERIAL GROUP:Interphase Mass Transfer
Group Description = Materials with reference properties suitable for performing either Eulerian or Lagrangian multiphase mass transfer problems.Examples include cavitation, evaporation or condensation. END MATERIAL GROUPry Redlich Kwong
Group Description = Materials with properties specified using the built in Redlich Kwong Equation of State. Suitable for dry real gas modelling. END MATERIAL GROUP:Wet Redlich Kwong
Group Description = Materials with properties specified using the built in Redlich Kwong Equation of State. Suitable for wet real gas modelling. END MATERIAL GROUPry Redlich Kwong RGP
Group Description = Materials with properties specified in TASCflow RGP files using the Redlich Kwong Equation of State. Suitable for dry real gas modelling. END MATERIAL GROUP:Wet Redlich Kwong RGP
Group Description = Materials with properties specified in TASCflow RGP files using the Redlich Kwong Equation of State. Suitable for wet real gas modelling. END MATERIAL GROUPry Steam
Group Description = Materials with properties specified in TASCflow RGP files using the Vukalovich virial equation of state. Suitable for dry steam modelling. END MATERIAL GROUP:Wet Steam
Group Description = Materials with properties specified in TASCflow RGP files using the Vukalovich virial equation of state. Suitable for wet steam modelling. END MATERIAL GROUP:Redlich Kwong Dry Steam
Group Description = Water materials which use the Redlich Kwong equation of state. Suitable for dry steam modelling. END MATERIAL GROUP:Redlich Kwong Wet Steam
Group Description = Water materials which use the Redlich Kwong equation of state. Suitable for condensing steam modelling. END MATERIAL GROUP:Redlich Kwong Dry Refrigerants
Group Description = Common refrigerants which use the Redlich Kwong equation of state. Suitable for dry real gas models. END MATERIAL GROUP:Redlich Kwong Wet Refrigerants
Group Description = Common refrigerants which use the Redlich Kwong equation of state. Suitable for condensing real gas models. END MATERIAL GROUP:Redlich Kwong Dry Hydrocarbons
Group Description = Common hydrocarbons which use the Redlich Kwong equation of state. Suitable for dry real gas models. END MATERIAL GROUP:Redlich Kwong Wet Hydrocarbons
Group Description = Common hydrocarbons which use the Redlich Kwong equation of state. Suitable for condensing real gas models. END END
COMMAND FILE: Version = 10.0 END
Old   August 31, 2006, 12:40
Joe
Why is BUOYANCY REFERENCE LOCATION: located at that particular position?
The air isnt feeling the gravity body force ...
Old   August 31, 2006, 13:02
Miguel
Since ptotal=p+pref+rho.ref*(z-zref)*g, I choose zref on top of chanel in order to add hidrostatyc contribution due water. This is true if rho.ref=rho.water, but it isnt, right? rho.ref=rho.air.It`s my mistake. Where can I set zref?
Two phase flow with condensation Sunnie FLUENT 0 May 31, 2009 11:02
Two Phase immiscible Flow in a microchannel Flo FLUENT 0 October 23, 2008 12:39
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 03:32
Two phase flow models Atholl Main CFD Forum 2 May 7, 2002 04:49
swirling two phase flow Ken Schifftner Main CFD Forum 6 July 10, 2000 15:19
