Temperature dependent properties of liquid water
Old   September 3, 2020, 14:33
Default Temperature dependent properties of liquid water
Nicolas Misiara
NicolasMisiara is on a distinguished road
Dear all,
I am trying to select the most suitable set of physical properties for liquid water, with temperature dependency of the Specific heat, the Density, the Conductivity, the Dynamic Viscosity and Expansivity and so on...
Considering the available properties, the "Water Data,IAPWS IF97" seems to be appropriate for my simulation, and especially the "Water 1" because of the temperature range.
See the dedicated webpage :
http://www.iapws.org/relguide/IF97-Rev.html
I'm running a coupled Thermal-CFX analysis on a device submitted to a power flux, cooled down with water (that I need to keep liquid!). Therefore the aim is to assess the effectiveness of the cooling system with more reallistic physical properties.
Finally my question : have you already used this data set or would you recommend using an other one ?
I thank you in advance.
Best regards
Nicolas
NicolasMisiara is offline   Reply With Quote
Old   September 3, 2020, 20:03
The IAPWS water properties are the most accurate and complete properties for water.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   September 7, 2020, 03:52
Nicolas Misiara
Dear ghorrocks,
Thank you for your confirmation!
Best regards
Nicolas
Temperature dependent properties relation alimea Main CFD Forum 0 July 11, 2018 04:34
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Constant properties water with variable density as a function of temperature JuPa CFX 4 November 1, 2014 05:43
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
how to incorporate temperature dependent thermophysical properties in fluent. CANDY Fluent UDF and Scheme Programming 4 October 22, 2012 05:19
