August 29, 2020, 06:44 |
Boundary Conditions for Axial Flow Fan
Zero
Rep Power: 6 |
Hi. I'm trying to simulate a small axial fan that is placed in a duct, so the whole setup looks kind of like a small wind tunnel (see picture below). The problem is that I've tried multiple boundary conditions, but both total and static pressure always drop after the fan, which is not physically possible. The fan has a diameter of 78mm, rotates at 20000 rpm and has a modified inlet and outlet for better flow characteristics. I've seen suggestions at other threads, but nothing seems to work, except if i set 0 Pt at the inlet and 0 Ps at outlet, then i get a pressure increase but i don't know if this is a valid approach.
Any help would be appreciated. Thanks in advance. |
August 29, 2020, 11:36 |
Gert-Jan
Rep Power: 28 |
Need more info to be able to help. Please share your output file.
And show where inlet and outlet are. |
August 29, 2020, 15:16 |
#3 | |
Zero
Rep Power: 6 |
Inlet is at the left of the image. The concept is that i need to design a small scale fan (fitted in a 8x8cm casing) in order to replace the one currently used (a CPU fan of the same size) in a small wind tunnel that is used for multiple experiments. In CFX I've imported 4 domains; the inlet duct, the fan, the fan hub, and the outlet duct. For the fan domain, i simulated one blade passage in turbogrid and then did a turbo rotation in CFX pre in order to get the whole domain. I used turbogrid for the fan meshing, mainly to get a good quality hexa mesh. The rest are meshed in ICEM. Also the hub is the only solid domain. Finally, there are 5 interfaces; 2 for the connection of the fan with the ducts (inlet/outlet), same for the hub and one for the hub/fan connection. As i said, I've tested multiple cases, mainly changing the boundary conditions but the results always show a drop in pressure after the fan. Inlet domain is 0.2m long and outlet 0.4m. Longer outlet lengths have been tested but there is no difference in the results. Last edited by petrosdd; August 30, 2020 at 04:43. Reason: removed link |
August 29, 2020, 19:18 |
Gert-Jan
Rep Power: 28 |
Please don't use links to other software. We don't know what's behind. Just keep the output on this forum. Use "Go advanced:" to up load text files.
Also, I am not going to open results files. We're not helpdeks employees. Just share your results in figures like streamlines, velocities, pressure, total pressure, etc. |
August 31, 2020, 05:41 |
#5 | |
Zero
Rep Power: 6 |
Ok sorry for the link, it's my first time asking and i thought you needed the .res file as well. The figures below, are from a previous run, with the only difference being the lower rpm of the fan, lower inlet speed and the absence of the modified fan inlet/outlet. So, it's just a straight duct, with a fan and its case in the middle. The flow always moves from left to right in the pictures. Axis of rotation of the fan is Z and ω is negative (-7000rpm). As an inlet BC I've specified the total pressure knowing the inlet velocity (reference pressure is 1 atm so Pt is just 1/2*ρ*V^2, where V=11m/s, thus Pt=74Pa) and outlet BC is static pressure which is set equal to 0. Also, I'm doing a frozen rotor simulation and the SST model is used. As i said, the fan acts like a turbine, extracting energy from the fluid instead of adding any. I can't upload the .out file, because the size is too big. Ps ch.jpg Pt ch.png Ps fig YZ.png Ptot fig YZ.png slines.png |
August 31, 2020, 05:49 |
Rep Power: 12 |
August 31, 2020, 06:08 |
Gert-Jan
Rep Power: 28 |
It is not necessary to upload the complete output file. Only the top part with all settings will do.
When plotting streamlines or velocity, use Velocity in Stationary Frame. This helps interpreting the results as a stationay observer standing in the laboratorium. Since streamlines will stop on the fan blades, it is best to let them start on both interfaces and use forward and backward calculation/. Are you sure your shroud wall is counter rotating? Since it is the rotating domain, it will stand still effectively. I would set Total pressure or Velocity on the inlet and static pressure 0 [Pa] on the outlet. Then the static pressure on the inlet should be negative. Then increase velocity or decrease total pressure on the inlet values several times to generate a fan curve. Alternatively, increase or decrease the rotational speed. Using affinity rules you can generate other points. Mostly, my results using CFX are spot on. |
August 31, 2020, 06:30 |
#8 | |
Zero
Rep Power: 6 |
Setting a total pressure value on the inlet (e.g. my 74Pa) and a static pressure of 0Pa on the outlet, always results in a pressure drop after the fan. Same happens when i set velocity. The only case where there is a pressure rise, is when i set Pt=0 at the inlet and Ps=0 at the outlet, if that's what you mean.But i don't seem to grasp the meaning of it. |
August 31, 2020, 06:45 |
#9 |
Gert-Jan
Rep Power: 28 |
CFX is just trying to solve the case that you set. It cannot think for it self. So if you apply 74 Pa on the inlet, CFX will adapt the flow such that 74 Pa is obtained. No matter what your fan does. It can stand still, rotate clockwise or counter clock wise.
So now you have 74 Pa on the inlet. Apparently that is too much. In fact you are forcing the air through the fan, no matter what it is doing. The fan cannot add anything to it. It is more like a resistance. Better set 0 [Pa] total pressure on inlet and 0[Pa] static pressure on the outlet. Then let the fan pick up the air by itself. The static pressure on the inlet will drop, giving you the head you are looking for. Then increase or decrease the fan speed to create a fan curve. So your second case is correct. In that case, you let the fan do the work instead of your boundary condition. |
August 31, 2020, 07:56 |
#10 | |
Zero
Rep Power: 6 |
September 2, 2020, 08:19 |
#11 |
Henrique Stel
Rep Power: 17 |
Let me add one thought:
Defining turbomachinery problems in terms of pressure on both the inlet and outlet (either total or static) is a very unstable setup. I would prefer a specified total pressure at the inlet and a specified mass flow rate at the outlet. You know the velocity, so why not setting the mass flow rate? I agree with Gert-Jan that your setup may be resulting in a high mass flow rate so that your fan is choking (not increasing pressure). |
September 2, 2020, 10:23 |
#12 | |
Rep Power: 33 |
1 - Case where the Pressure Ratio vs Mass Flow Rate curve is nearly flat for an interval of mass flow In such situations a Total Pressure Inlet+Static Pressure outlet is not a great combination because any mass flow in that interval is nearly a solution; therefore, the solver will wander around that solution space. 2 - Case where the Pressure Ratio vs Mass Flow Rate curve has a sharp drop/increase, i.e. narrow range of mass flow rate represents a large change in pressure. In such situations, a Total Pressure Inlet+Mass Flow Rate outlet is not a great combination because any value of Static Pressure at the outlet will support the specified mass flow rate during convergence; therefore, the flow may converge very slow or wander around the solution space. The only known boundary condition pair in ANSYS CFX that adjust itself to both extremes and anything in between is the Total Pressure+Exit Corrected Mass Flow Rate since the effective mass flow rate is adjusted as the solution is converging. Hope the above helps,
September 2, 2020, 11:09 |
#13 | |
Henrique Stel
Rep Power: 17 |
Anyway, I guess that the guy has now some ideas to try and see what could work for him. At the end of the day if you have a bunch of possibilities all of which are physically feasible, the best should be the most stable/fast converging one. Only testing will tell which one will be them. |
September 2, 2020, 15:58 |
#14 | |
Zero
Rep Power: 6 |
September 2, 2020, 16:45 |
#15 |
Rep Power: 33 |
Have you looked at the rotational velocity vector in CFD-Post?
Is the rotor speed specified correctly? For the software, a fan, a compressor or a turbine looks the same. It is the direction of rotation that defines the behavior. If you are seeing a pressure drop, sounds more like an expansion from inlet to outlet. It is very common to get the rotation speed confused when the direction axis is specified backwards, or the angular velocity as negative. Perhaps?
September 2, 2020, 16:48 |
#16 | |
Zero
Rep Power: 6 |
Both rotational speeds have been tested. Obviously, when I set the wrong one, the streamlines are chaotic even before the fan. |
axial, boundary, cfx, conditions, fan |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
