CFX not converging for steady state 3D wing run |
Thu Win
Rep Power: 9 ![]() |
![]() ![]() My 3D wing run residuals aren't converging Any idea how to improve this? My box are 10x the chord length. |
Rep Power: 11 ![]() |
Thu Win
I don't suppose you have access to the 2020R2 CFX manual or know where I can download it? I'm using a lab computer for CFX but I want to read the manual on my own pc. However, it's asking me to register using an Ansys customer ID.
Edit: how can I do this? "View the residuals on a representative plane or as a isosurface with a lower then your maximum residual as value." What do you mean iso surface with a lower than your maximum residual as value? |
For manual - use older versions available on the internet, or ask your advisor for access to documentation.
For residuals - in the output control tab enable "Output Residuals" checkbox. Thus your results will contain residuals and you can work with them like with other variables. ![]() |
Thu Win
Thanks. I've checked my residuals and they look to constant.
I plot them as a contour on a plane on the XY axis. |
BTW, 40 iterations is usually too low to achieve convergence. Do you run simulation for longer periods? Residuals may "bounce" - decline non monotonically, with some local "peaks".
Thu Win
I will run it overnight with more runs
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
CFX run crash, integrating .res and .mon file | sidharath | CFX | 3 | May 24, 2016 05:44 |
HELP PLEASE! CFX Solver run ended abruptly due to power blackout | RobBanks | CFX | 10 | May 19, 2016 12:43 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
