Blade Loading turbo Chart?
Old   August 17, 2006, 05:08
Default Blade Loading turbo Chart?
prayskyer
when i use that blade loading turbo chart,i found the temperature isn't appraprate, a little bit more higher, is there a range when i came out the temprature^?
Old   August 17, 2012, 03:46
Default blade loading chart
mausam24's Avatar
Mausam Shresha
mausam24 is on a distinguished road
how can we get blade loading chart for different blade loading span
for example: chart for 20%of blade span? in CFX result
mausam24 is offline   Reply With Quote
Old   August 23, 2012, 12:46
Smile
mistry
csmistry is on a distinguished road
Blade loading is basicaly showing pressure variation on blade surface. that in aerodynamic term we say Cp. It is batter to go through this cp plot!!! secondly blade loading feature in turbo mode gives an option to see blade loading at different span...
csmistry is offline   Reply With Quote
Old   August 24, 2012, 01:20
mausam24's Avatar
Mausam Shresha
thank you for reply.I cannot properly map the pressure in CFX and FEM. can there be any better way to perform it . i am performing the mechanical Design of Francis turbine using FSI?
Old   August 26, 2012, 06:30
mistry
Not much idea for turbomachines but you can consider pressure distribution on blade surface and use this data for FEM analysis considering cantilever beam and hub to be fix end load as pressure load already obtain from CFX. in start up manu only you can do it.
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
Blade tip with tetra/prism method vinc ANSYS Meshing & Geometry 0 May 17, 2011 16:22
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 18:06
Meshing a 3D, tapered and twisted blade with Gambit-TGrid teskio ANSYS Meshing & Geometry 0 July 3, 2009 11:36
turbo file, need help chandra manik FLUENT 1 October 21, 2004 08:38
