Problem with .mdef with initial conditions and interpolator
Old   August 6, 2020, 10:41
Default Problem with .mdef with initial conditions and interpolator
Xiayang Gu
Xiayang is on a distinguished road
Dear Sir or Madam,
As part of my research, I am examining a rotary compressor whose volume changes over time. The working chamber is pulsating, so that large volume changes due to convergence problems require a mesh exchange. Due to the well-known rotary movement, I have therefore prepared the meshs in advance and implemented the transfer via a configuration file in CFX and defined a working cycle of the chamber in several flow analyzes with the associated networks.
When the information about the flow field between 2 networks is transferred, there is a so-called "mesh jump", in which the chamber rotates by a certain angle. From the CFX manual, I could see that CFX performs an interpolation when starting a new .mdef file with initial values. I suspect that the mesh jump is due to the interpolation. Do you have an idea how I can solve this problem with the mesh jump?
I have attached a screenshot of my configuration file and a video for clarification. Thank you so much!
https://www.dropbox.com/s/j396v1o17a..._Jump.wmv?dl=0
Best regards
Xiayang is offline   Reply With Quote
cfx;transient;mdef
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Closed Domain Buoyancy Flow Problem Madhatter92 CFX 6 June 20, 2016 22:05
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
combustion problem mcnair CFX 9 March 22, 2011 15:06
