Mesh?
Old   August 9, 2006, 13:42
Default Mesh?
Joe
While running a simulation how can you tell that the mesh is responsible for failing the run? In my case I cant get passed 17 iterations due to several problems since there are many parameters to be changed but how do I understand that finally can be the mesh? Even if I have checked the quality and everything in ICEM.
Regards.
Old   August 10, 2006, 05:53
Default Re: Mesh?
Michael B
years of hard experience Try to switch the turbulence on after iteration 17+.
Old   September 12, 2006, 11:57
Default Re: Mesh?
Fusion
You can launch again the simulation and save a backup file just before the failing: checking the result wil help you finding the cause! The presence of elements with negative volume (or a volume too small) or too much high lenght ratio, and non-overlapping interface elements are the most common problems for a mesh. If you ave checked everything, just try to change the number of nodes (also +1!) and the problem should vanish. F
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 11:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 02:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
