creation of 3d bodies within an assembly
Old   August 7, 2006, 18:47
Default creation of 3d bodies within an assembly
Roland
Hi all
This is a followup to an earlier thread. Im trying to model airflow through an engine bay for a car. I want to use a momentum sink for the radiator, as this is much simpler than is modeling fins/tubes/etc. Problem is, I have no clue as to how to define the radiator as a separate 3d region within a single assembly created in Design Modeler. Effectively, I need to create a domain for the chassis/engine, and a subdomain for the radiator (to apply the momentum loss through that area), but since the radiator is geometrically contained within the bounds of the chassis, I dont know how to physically model it. Any guidance is appreciated-
Regards,
Old   August 8, 2006, 12:49
Default Re: creation of 3d bodies within an assembly
longbow
You can use "Add Frozen" to create a domain inside a big one.
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 14:14
[ICEM] un-create assembly tav98f ANSYS Meshing & Geometry 0 September 23, 2011 12:17
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 12:52
surface bodies from design modeler to CFX chisa CFX 0 June 9, 2010 12:36
Stress Discontinuity between sliced Bodies - WORKBENCH mankle ANSYS 0 May 6, 2010 03:54
