Steady State Wave maker simulation with VOF Model |
#21 | |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Alexander has missed mentioning one important way of making simulations faster - which is to go parallel (or add more parallel nodes if you are already parallel).
#22 |
Saeed Pashazanousi
Rep Power: 6 ![]() |
Thanks Karachun for your attention and your time spent
I mean coding is programming for Boundary value problem of solution in Matlab or some other software... the solution is in a infinite time when the system reach a stable state...You definitely know the time dependent part of solution frequency is known and we assume a Sinusoid wave...I need the boundary value problem part of solution...I'm trying use CFX to solve it...May be I should programming a CFD code in Matlab...If you have a idea I will be happy to read about it... Thank you all
Best regards Saeed Pashazanousi Urmia University Email: st_s.pashazanousi@urmia.ac.ir |
#23 |
You may well be able to speed this up using boundary element methods, spectral methods, modal analysis or any of the myriad of other methods out there. But CFX supports none of this, it can only do steady state and transient (ie time domain) simulations.... Although noting it does have a frequency domain model for rotating machinery.
But it sounds like you should forget CFX and look at all the other approaches. But this is the CFX forum, so we won't be able to help you much there.
#24 |
Saeed Pashazanousi
I know this question was long ago, but It is worth saying that I solved my problem using Ansys's Acoustic harmonic module, using a FEM-based solver, instead of CFX, which is a CFD-based solver. Ansys's Acoustic harmonic can accurately simulate harmonic loads and boundary conditions. Although this method is based on FEM, not CFD, It is a promising method to study FSI under harmonic loads. If you need to investigate a thermal or electrical field simultaneously with the acoustic field, use Ansys Coupled Field Harmonic.
ansys 13 work bench, cfd, cfx, cfx 16, fluid |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
Droplet is just getting disaaper after Steady state VOF model | raushan kumar | Fluent Multiphase | 0 | May 20, 2019 09:32 |
Weird results in MRF simulation of stirred tank with a steady state k-w SST model | aminem | OpenFOAM Running, Solving & CFD | 2 | January 3, 2015 11:21 |
2d axisymmetric simulation of supersonic jet on liquid surface using VOF model | DKanungo | Fluent Multiphase | 0 | June 20, 2014 02:15 |
Steady state simulation with transient partilcle tracking | mali28 | FLUENT | 2 | February 7, 2013 14:25 |
