Negative volume problem in Two-way FSI coupling |
August 5, 2006, 10:05 |
Hi I am using Ansys 10 and CFX 10 for the two way FSI coupling with MFX license.I have been trying to simulate large deformation problems (in elastic range), but every time when i run, after few timesteps solver exits with a negative volume error.How to overcome this? but this interface works well with small deformation problems.
Some people say restart your analysis form the deformed structure (i.e with a new mesh),if it so does anybody have experienced this type of problem?. I am bit confused how exactly i have to proceed. Any thought on this would be appreciated. Thanks in advance Fred |
August 7, 2006, 13:17 |
Re: Negative volume problem in Two-way FSI couplin
Hi Fred,
Have you tried setting the mesh stiffness in CFX? Usually a value of 1 [m^3 s^-1]/Wall Distance or 1 [m^5 s^-1] will solve the problem (see the help doc for more info). You could also try reducing your timestep so that the mesh deformation isn't so drastic. If you have done both of these things, then maybe your initial mesh quality needs to be improved as suggested. Often meshing a geometry somewhere in between where you expect the geometry to begin and end is a good starting point. |
August 8, 2006, 04:27 |
Thanks johnny for your information.
I used the mesh stiffness of 1/wall distance and i tried with the different range of timesteps,but still the cfx solver fails after 15 seconds as the deflection is more in this timestep. Can anyone could detail the procedure of using the last timestep file as the initial file for the next timestep for FSI Analysis (in both Ansys and CFX)?. Fred. |
August 16, 2006, 11:03 |
Hi there,
Unfortunately, I am not going to be much help because I am also running 2-way coupled FSI sims between CFX and ANSYS 10 and achieving the same errors. I have used both a mesh stiffness of 1/walldist. and 1/ctrl. vol. and numerous times my simulation has failed due to negative elements being generated (currently my errors are not solved). The reason for my reply is that I am looking at psudoelastic large deformation problems, and I am receiving the same error messages. Is there a chance that there is a bug in the coupling code? Let me know if you have had any breakthroughs. Some of the tips ANSYS tech support gave me are: * check units. make sure the units of the geometries in ANSYS and CFX match. Also make sure that the solution units in CFX match the units used to define the ANSYS model. * double check the material properties, make sure the solid properties of ANSYS are reasonable etc. The solid and fluid domains of the simulation should be able to run ok when looked run in a decoupled analysis |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
error in two way fsi | kmgraju | CFX | 1 | May 2, 2011 03:32 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 03:39 |
Negative Volume Problem | Alicia | Siemens | 1 | July 27, 2005 08:05 |
Problem in identifying Negative volumes in Fluent | Senthil | FLUENT | 1 | April 19, 2003 11:16 |
