July 30, 2020, 01:49 |
design a kaplan turbine using ansys cfx
amirhossein
hi sir,
i am designing a kaplan turbine with a prescribed head and volume flow rate with a specific efficiency i have done basic design in matlab by a code and obtained required radius, inlet and outlet blade angles,stagger angles and axial chords for both inlet guide vane and runner blades i decided to apply 4 runner blades and for each 3 guide vane blades then i exported generated domains to turbogrid and generated a structured mesh with a good quality by it. and finally exported the mesh into cfx-pre and adjusted the relevant settings in cfx(for example angular velocity,b.c. and interfaces and expressions definitions). my problem is i get a power much larger than that i should and that is my design value) i have seen many videos on youtube and they did not work. i ask you to help me if you can. regards |
July 30, 2020, 03:21 |
Rep Power: 144 |
axial turbine modeling in ansys design modeler | khosroaz72 | ANSYS | 0 | May 6, 2018 14:11 |
Flow driven of darrius turbine using ANSYS cfx | TKP | CFX | 3 | April 9, 2015 05:38 |
ICEM of ANSYS V15: how to export .msh mesh for CFX | hydroaero | ANSYS | 1 | March 9, 2015 23:17 |
ICEM of ANSYS V15: how to export .msh mesh for CFX | hydroaero | CFX | 1 | March 9, 2015 23:15 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
