Flow distribution in porous domain (CFX)
Old   July 28, 2020, 04:03
Default Flow distribution in porous domain (CFX)
William
CFXer is on a distinguished road
Hello
I am trying to simulate a heat exchanger as a porous media.(using CFX's porous domain)
So it has several channels that have flow non-uniformity.
I want to observe how the flow non-uniformity varies with the heat exchanger's header shape.
In my pre-test, the flow non-uniformity occurs at the start point of the heat exchanger's core, but as the flow proceeds to the end of the core, the velocity of every channel to be equalized.
Is it normal to be equalized the flow velocity in porous media? I have searched Ansys help and google, but nothing has come out.
Anybody knows how the flow proceeds in porous domain in CFX and why the flow uniformity occurs in porous media? and if I want to maintain the flow non-uniformity through the whole domain, how can I set up the solver?
Thank you in advance.
CFXer is offline   Reply With Quote
Old   July 28, 2020, 05:12
karachun's Avatar
karachun is on a distinguished road
Does flow channels have a common inlet part? If so then this looks reasonable. Fluid flows on a path of minimum resistance, higher speed mean greater resistance and higher energy losses.
I observe a similar effect when one user places some porous media after inlet with some swirling velocity profile (profile was used to model flow after fan). Flow rapidly becomes straight because swirled flow meahs longer path of elemental fluid particle and therefore higher resistance and therefore is not preferable from an energetic point of view.
karachun is offline   Reply With Quote
Old   July 28, 2020, 07:11
William
I observe a similar effect when one user places some porous media after inlet with some swirling velocity profile (profile was used to model flow after fan). Flow rapidly becomes straight because swirlad flow meahs longer path of elemental fluid particle and therefore higher resistance and long path therefore is not preferable from an energetic point of view.
Yes, the flow channel is a long cuboid-shaped channel. (a plate shape)
So, you mean the flow must be mixed through the fluid channel, not only porous domain but also fluid domain?
Old   July 28, 2020, 08:38
karachun's Avatar
No, I mean that it is expected that porous medium enforce nonuniform speed field to become more uniform.
Old   July 28, 2020, 20:45
William
Oh I understand. Thank you!
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Rotational porous domain Pifpoffele CFX 1 July 6, 2015 12:46
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 05:07
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
