Reynolds Number Outside the Range ??
Old   July 28, 2006, 11:50
Default Reynolds Number Outside the Range ??
Manu
Hi I ve two queries: 1) i am setting the reynolds number for a backward facing step flow with 3D geometry in CFX.When i am reaching above Re =1000 a warning is coming " Reynold Number is outside the range specified ".It is obvious that i am selecting a Laminar Model in Pre.I exactly dont understand is this error message has to do something with my solution or its just a warning. I am not getting this message in 2D Simulation. 2)
Warning comes after 4-5 iteration "a wall has been placed at the outlet boundary , consider opening b c ....." After appearing 2-3 times it disappears.Than solution converge smoothly.
Why it shows this message ?? What it haas to do with solution?? I ve checked all the grids in ICEM.
-Manu
Old   August 7, 2006, 13:39
Default Re: Reynolds Number Outside the Range ??
johnny
Error 1 is telling you the Reynolds number is high, and that you should probably be running with a turbulence model. The Reynolds number will be different for your 2d and 3d cases since CFX uses the average length scale (cubed root of volume) for calculating Reynolds number, not the proper characteristic length. You should check to see if running laminar is sensible for your case.
Error 2 is not a problem. If you get final convergence with a wall at the outlet, you may want to consider moving your outlet further downstream.
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 8, 2009 00:51
Reynolds Number Outside the Range ?? Manu CFX 4 August 29, 2006 13:16
Reynolds Number for Nozzle Shyam Main CFD Forum 4 March 2, 2006 08:15
Help with Reynolds number: Re Isa Main CFD Forum 2 December 4, 2003 10:47
High Reynolds Number Incompressible Flow Nick Lavery Main CFD Forum 3 February 19, 2002 16:47
