ANSYS problem in solving fluid fluid interaction |
July 24, 2006, 10:03 |
please help me , can i use simple ansys 10.0 Flotran for simulating free stream flow over a plate with a angled hole in the plate in which same fluid is flowing with different properties.. for film cooling of the plate...i have only option to work in flotran cfd.... could i try the two different flows as two materials or if i use single type of material then it is posing problems saying soluition is diverging. i have tried all the methods...pls help me if some one has worked on such a problem
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 22:51 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 09:30 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 06:36 |
