Best Turbulence Model for a Gas Turbine Simulation |
July 14, 2020, 15:57 |
John Titor
Rep Power: 6 |
I want to obtain temperature and velocity profiles of flow through four gas turbines, that are placed as depicted below. The simulations are being done for a hoverboard model. I am just using simple cylinders to depict the turbines. Air enters the turbines through the inlet, the turbine walls provide the heat flux, and the air then exits the exhaust at much higher temperatures. I am curious about what the turbulence model should be used to model this flow, and if you can in general provide any tips for such a simulation? I'd be grateful. |
July 14, 2020, 15:59 |
Images
John Titor
Rep Power: 6 |
July 14, 2020, 18:35 |
Rep Power: 144 |
I don't look at third party download sites. Post images directly on this forum.
From what I can see you should consider using a momentum source term to be the turbines. Then you can control the thrust/power they generate without modelling the details inside the turbine. Also the heat flux of the turbines is unlikely to be important, the momentum flux will be the important factor as they gives the thrust. The choice of turbulence model is unlikely to make much difference. But once you have a working model you can try some models and test this for yourself.
July 21, 2020, 08:59 |
John Titor
Rep Power: 6 |
July 21, 2020, 18:44 |
Rep Power: 144 |
Are the turbines are inside the domain? They appear to be. This would mean that the inlet and outlet of the turbines are inside the domain. If this is the case you should use a momentum source term, which can be found when you define a subdomain.
If the turbines have their inlets or outlets outside the domain then you should use an inlet or outlet boundary to define them.
cfx, cylinders, propulsion, turbine, turbulence |
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) | remidemol | OpenFOAM Running, Solving & CFD | 3 | May 26, 2020 05:47 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Change Turbulence Model during simulation | bussaco8 | OpenFOAM Running, Solving & CFD | 4 | June 1, 2018 13:48 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Turbulence model for turbine blade cooling | CFD Student | FLUENT | 0 | December 20, 2004 08:30 |
