Error message in CFX solver
Old   July 14, 2020, 04:26
Default Error message in CFX solver
William
CFXer is on a distinguished road
Hello!
The solver stopped my simulations after only 3 timesteps given the following error message:
Slave: 10
Slave: 10 +--------------------------------------------------------------------+
Slave: 10 | PROBLEM ENCOUNTERED WHEN EXECUTING CFX EXPRESSION LANGUAGE |
Slave: 10 | |
Slave: 10 | The CFX expression language was evaluating: |
Slave: 10 | Resistance Loss Coefficient |
Slave: 10 | |
Slave: 10 | The problem was: |
Slave: 10 | LOGe-OF-NON-POSITIVE |
Slave: 10 | |
Slave: 10 | FURTHER INFORMATION |
Slave: 10 | |
Slave: 10 | The problem was encountered in executing the expression for: |
Slave: 10 | $SCALAR_0 |
Slave: 10 | The complete expression is: |
Slave: 10 | (0.79*ln(Re)-1.64)^(-2)/0.733[mm] |
Slave: 10 | The error occurs on sub-expression: |
Slave: 10 | ln(Re) |
Slave: 10 | |
Slave: 10 | BACKGROUND INFORMATION |
Slave: 10 | |
Slave: 10 | The error was detected at one location. The same problem may be |
Slave: 10 | present at other locations - that has not been investigated. |
Slave: 10 | The following values are for the first location which has the |
Slave: 10 | problem. |
Slave: 10 | |
Slave: 10 | In this expression, these sub-expressions have been calculated: |
Slave: 10 | |
Slave: 10 | Sub-expression = Value |
Slave: 10 | |
Slave: 10 | 0.79 = 0.790000 |
Slave: 10 | These values were set before reaching the current expression: |
Slave: 10 | |
Slave: 10 | Name = Expression = Value |
Slave: 10 | |
Slave: 10 | Re = density*(-w)*0.733[mm]/visc= -855.198 |
Slave: 10 | w = 0.154518 |
Slave: 10 | viscosity = 1.953092E-05 |
Slave: 10 | density = 147.471 |
Slave: 10 | |
Slave: 10 | END OF DIAGNOSTIC OUTPUT FOR CFX EXPRESSION LANGUAGE |
Parallel run: Received message from slave
Slave partition : 4
Slave routine : ErrAction
Master location : Message Handler
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Failed to calculate sources in GETSOU for LOSS_F2 from directory |
| "LOSSM/RESIST" on location "6!�� |
Slave partition : 4
| Message: |
| Stopped in routine GETSOU |
| ERROR #001100279 has occurred in subroutine MESG_RETRIEVE. |
| Message: |
| Stopping the run due to error(s) reported above |
I have searched about the GEUSOU error, but nothing has come out.
Does anyone know what this error message means?
Thank you in advance.
CFXer is offline   Reply With Quote
Old   July 14, 2020, 05:38
karachun's Avatar
karachun is on a distinguished road
Error is obvious. You have this set of expressions.
w = 0.154518
density = 147.471
Then you try to get natural logarithm from negative value - Re = -855.198.
You can not take logarithms of negative value (actually you can, you get complex numbers with imaginary parts but CFX can not handle imaginary parts and you don't want to work with complex numbers).
karachun is offline   Reply With Quote
Old   July 14, 2020, 07:28
William
w = 0.154518
density = 147.471
Thank you! I have solved the problem with your reply!
CFX Solver Manager Error Code 1 Peta247 CFX 3 June 4, 2016 12:00
The ANSYS CFX solver exited with return code 1. No results file has been created moodkiller CFX 7 May 23, 2016 03:16
CFX solver workspace & ourfile Problem wangy1767 CFX 1 January 9, 2013 10:38
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 17:42
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 23:54
