July 21, 2006, 03:31 |
Multiple Porosities
Does anyone have experience in defining different zones of different porosities for an air flow? I want to simulate the flow through a fill, with an inlet gas distributor (no filling, porosity=1) an an outlet collector (same problem). Meshing was no problem - I just defined walls between the different zones and a new part/material point for each zone in ICEM. If you have set up something like this in CFX-Pre before please let me know how you did it! Cheers Bernhard |
July 21, 2006, 08:30 |
Re: Multiple Porosities
Have you looked at the Catalytic Converter tutorial?
July 21, 2006, 09:34 |
Thanks Robin!
That's what I was looking for. Cheers Bernhard |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Interpolating a results file onto multiple identical domains | jtipton2 | CFX | 0 | June 7, 2011 12:44 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
Multiple domain/Multiple material problems... possible or not? | Amiga500 | OpenFOAM | 1 | April 14, 2010 16:32 |
Multiple reference frames? | Moon | Siemens | 0 | March 4, 2003 07:32 |
