July 7, 2020, 08:07 |
change heat of combustion
mohsen
Rep Power: 6 |
hi,
I am using ANSYS-CFX to model a propane reaction. Heat of combustion of propane(ΔcHo) is 50 MJ/kg but i want change manually ΔcHo of propane in CFX. Can you help me? Tnx |
July 7, 2020, 08:32 |
Rep Power: 33 |
The heat of combustion is not a material property, but the result of a reaction between materials.
If you look at the material data for Propane in ANSYS CFX you can see enthalpy reference accounts for the heat of formation. I wonder why you would like to change such a value, perhaps you may want to adjust the heat of formation of your fuel? Hope the above helps,
July 7, 2020, 08:46 |
mohsen
Rep Power: 6 |
Tanks for your help.Yes i want change heat of formation of fuel. I want set for example 20 MJ/kg for propane. Heat of combustion for propane by default is 50 MJ/kg but i want change manually. In CFX in select propane w2D for reaction but i want change heat of fuel for propane. I hope explain good.
July 7, 2020, 15:18 |
Rep Power: 33 |
Go to the Propane material definition, and check the Reference State of the material
If the heat of the fuel changes from 50MJ to 20MJ, I doubt it is the same material. Also, keep in mind ANSYS CFX does not use the heat of combustion, or heat of fuel explicitly anywhere in the combustion model. It uses thermodynamic properties of the material. The ANSYS CFX implementation of the energy equation does not use any split of the enthalpy material definition.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum. Last edited by Opaque; July 7, 2020 at 15:22. Reason: Complete message |
July 8, 2020, 00:23 |
mohsen
Rep Power: 6 |
I checked Material Properties of Propane and found Reference Specific Enthalpy .Is this same ΔcH0 or heat of fuel? In fact i want the propane to burn at a lower latent heat. Tanks a lot for your Answer |
July 8, 2020, 08:32 |
Rep Power: 33 |
My advice at this point is to read the documentation, and complement it with a thermodynamics book and look the heat of formation for propane.
Heat of formation is NOT heat of combustion.
July 8, 2020, 08:38 |
mohsen
Rep Power: 6 |
yes Heat of formation is NOT heat of combustion.I can not find Standard Enthalpy Materials in CFX?can you help me?
July 8, 2020, 11:02 |
Rep Power: 33 |
Sorry.. Do not understand your last question?
"Standard Enthalpy Material". What do you mean by that?
July 11, 2020, 01:04 |
#9 |
mohsen
Rep Power: 6 |
i explain otherwise.I have e reaction for Propane and heat of combustion is 24.2 MJ/kg. I don't know how to set 24.2 MJ/k in CFX? Tnx |
July 12, 2020, 18:59 |
#10 |
Rep Power: 33 |
My advice is to go back to the fundamentals and you will see how it comes out immediately
Write down the formula for the heat of combustion of the specific reaction you have. You must make clear assumptions, for example, complete or incomplete reaction. Which other materials are present, and what is the total composition: Assumptions for the equation below: 1 - Complete combustion 2 - Constant specific heat Say A * Propane + B * O2 + C * N2 --> D * CO2 + E * H2O + F * N2 Write down the heat of combustion formula as a function of the enthalpies defined as: h_material = h_material_ref + Cp_material (T - T_ref) Once you work out the heat of combustion, it should be a function of the reference enthalpy of your type Propane and the adiabatic flame temperature for the value you have. Hope the above helps,
July 13, 2020, 04:19 |
#11 |
mohsen
Rep Power: 6 |
Hi dear Opaque,
tanks a lot. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Heat Release vs. Apparent Heat Release // Comparison with GT Power | MFGT | CONVERGE | 10 | August 17, 2016 02:38 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Phase Change Heat Conduction | hawkeye321 | OpenFOAM | 14 | April 30, 2011 14:24 |
