Expressions and FSI Question
Old   July 17, 2006, 10:44
Default Expressions and FSI Question
chris b.
Greetings,
I am running FSI Sims with two way coupling between ANSYS 10 and CFX 10. My difficulties lie in establishing a good mesh stiffness. I read in tutorial 20 that a good mesh stiffness would be 1 / the volume of the control volume. However, I do not what commands I need to enter in the CEL epression language to get "the volume of the control volume." I have looked in the help files of CFX and still have not been able to find the information I need. If someone already knows or can point me in the correct direction, I would greatly appreciate their assistance.
Old   July 17, 2006, 11:31
Default Re: Expressions and FSI Question
Robin
The variable 'volcvol' gives the volume of the control volume. It has dimensions of volume (L^3), so you will need to normalize this by dividing by 1[m^3] and multiply by the appropriate dimensions to use it as stiffness. You could also use 1/wallscale, which will make the mesh stiffer near the walls.
Version 11.0 will have some pre-defined stiffness options which do something similar.
Regards, Robin
Old   July 17, 2006, 12:50
chris b.
Thank you so much!!!
FSI Mesh stiffness Andrew.Coughtrie CFX 3 July 29, 2011 04:50
error in two way fsi kmgraju CFX 1 May 2, 2011 03:32
FSI - Specified Mesh Displacement Vinzent CFX 2 September 17, 2010 08:09
