July 13, 2006, 10:03 |
BATCH PROCCESSING
I have made pressure loss calculations with ansys cfx. I have programmed the basic darcy weisbach equation in order to get such losses. I have validated it comparing the results of the simulation with calculations by hand using the same model. The proccess is as follows:
1.- I have done a model of a straight tube. 2.- I have given as constant value for the problem the friction factor in darcy-weisbach equation. This factor can be obtained by use of Moody's chart, but I want to use the cfx capabilities in order it can calculate it directly. so I have an equation that gives the same result than Moody's chart. This is the colebrook-white equation. This equation solves the friction factor as a funtion of itself, so if you want to solve it you must solve it by iteration. This is the first question: Is there anybody who knows how can i program an iteration in ansys cfx? colebrook-white equation is as follows: 1/sqrt(lambda)=-2*log(k/(3.7*D)+2.51/(Re*sqrt(lambda))) The second problem is the following: I have given initial conditions to the model. I have specified a determined flow rate, but it's constant. So if i want to obtain pressure losses for several flow rates I should run the same simulation several times varying the flow rates in ordel to get such losses. The question is: Is there any way to do this in such a way that I can specifiy a flow rate range and ansys can execute the simulation in the flow range specified? How could I program a bath proccess in ansys cfx? Thanks in advance |
July 14, 2006, 02:19 |
Re: BATCH PROCCESSING
Batch mode: CFX Community, Technical Tips: Running solver jobs in batch and job scheduling 27 October 2005
July 14, 2006, 11:04 |
More commands can be viewed from the command line (DOS window) started through CFX launcher by running:
cfx5solve -help |
July 14, 2006, 13:23 |
Hi Roberto,
I'm not sure I understand what you are trying to do. Are you calculating the friction factor to apply at a boundary condition? To calculate the friction factor directly, use the Swamee-Jain equation instead http://en.wikipedia.org/wiki/Swamee-Jain_equation. Regards, Robin |
July 15, 2006, 13:22 |
Hi, Robin. I have seen the Swamee-Jain ecuation, and I have validated it by comparing it with the colebrook white ecuation. I have found that it gives results within 0.0001 accuracy so this time you have helped me to solve the friction factor without the use of iterative proccesses.
So now I need to investigate the advice given to me respect to batch proccessing. |
July 15, 2006, 13:30 |
Hi Patrick, where should I find the document that you are refering to?
Run Multiple Files in Batch | nickninevah | STAR-CCM+ | 6 | October 12, 2017 07:17 |
to run a replayfile in batch mode from UNIX | froztbear | ANSYS Meshing & Geometry | 4 | May 13, 2014 09:00 |
[Question]About batch job | fluboy | FLUENT | 2 | August 12, 2009 12:10 |
Windows XP Batch file help needed | DL123 | Main CFD Forum | 2 | July 3, 2009 09:53 |
Running Job in Batch mode (EFD) | Nick Sessions | FloEFD, FloWorks & FloTHERM | 0 | April 16, 2008 17:44 |
