dyn. viscosity as a function of particle Temp.
Old   July 6, 2006, 11:48
Default dyn. viscosity as a function of particle Temp.
Felix
Hi all,
I would like to create a dyn. viscosity of my liquid particles as a function of the particle temperature. Has anybody experience with this? I am using CFX 10.0 and a lagrangian particle model. Is it possible to solve this problem without using fortran subroutines? If yes how can I find out the variablename of the particle Temperature?
Cheers, Felix
Old   July 7, 2006, 01:14
Default Re: dyn. viscosity as a function of particle Temp.
vipin
hi just explain ur problem clearly what ur simulating exactly
Old   July 7, 2006, 04:19
Felix
I am simulating the motion of liquid and inert particles with a diameter of 0.1 micron in a gas flow. You can define a value for the dyn. viscosity in the "material properties" -> "Transport properties" settings. And I want to create a function for this dyn. viscosity which depends on the particle temperature. The background of my question is that I would like to associate the perpendicular/parallel coefficient with that dyn. viscosity to obtain a behaviour for the stickiness of the particles. Do you need more information?
Felix
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
Casson Viscosity model as one user define function Zahra Rahmdel FLUENT 0 November 6, 2004 06:53
Why tne viscosity in LBM have tunning function? TSYen Main CFD Forum 0 October 25, 2004 21:54
Density of liquid Sapphire as function of temp. J.W.Ryu FLUENT 0 September 8, 2003 03:24
