Restart of FSI simulation
Old   July 3, 2006, 10:26
Default Restart of FSI simulation
V. Kumar
Hi all
Can anyone tell me how to restart a FSI simulation under the follwoing situations:
1) Restart from the "transient" solution from ANSYS (with no fsi) as an initial field for the FSI simulations.
2) A normal restart from previously stored FSI data.
I know how to make a restart from exisitng CFX solution but not for the case of ANSYS-transient (finite element solution) to MFX computation.
Can anyone explain the way to do this with one example each for the above mentioned situations? Or is it not possible in ANSYS10.0 to make above kind(s) of restarts?
thanks
Old   July 3, 2006, 12:48
Default Re: Restart of FSI simulation
Joe
What are you using for the FEM calcs? What platform/OS are you running on?
Old   July 3, 2006, 14:12
V. Kumar
I think I mentioned in my previous mail that I am using ANSYS-CFX10.0 for the FSI coupling using MFX. Operating systems Linux Suse9.0 64-bit AMD and Win-XP Intel 32 bit.
Old   July 20, 2006, 14:23
wallingj
I have viewed your ANSYS .dat file from your old item. You have to insert "save" to your old .dat file.
Then use the following steps
1, run the MFX until it finishes itself
2, insert these command to you .dat file /batch,list resume,ANSYS,db /solu mfrs,2.0 mfti,3 solve save
3, restart MFX
Now I am using the same software as you use to solve the FSI problems. I hope we could discuss this MFX program further.
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 01:37
2 way FSI simulation errors ninjabro CFX 1 September 8, 2011 09:23
FSI: change material parameters before restart Lance CFX 2 September 30, 2010 09:38
FSI simulation is DEAD SLOW Lance CFX 6 September 12, 2009 10:00
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
